I have an external drive with files that I want to keep on there. Can I use FreeFileSync to create a backup of my Mac internal drive onto my external drive without impacting any of the files that are already on my external drive? For example, doing a one way mirror sync, from my Mac laptop to an external hard drive, could I have the files from my Mac transferred to just a folder on the external without affecting any other data on the external?
Thank you
Can I use FreeFileSync to create a backup without erasing an external drive?
Yeah, I would suggest creating a folder on the external and syncing to that
Perfect, thanks for your response. I tried that and it worked well.Yeah, I would suggest created a folder on the external and syncing to that xCSxXenon, 31 Mar 2023, 19:43
