RealTimeSync.exe Does Not Provide a Target Location Text Box
When I ran RealTimeSync.exe it does not provide a target location text box to allow me to provide a target directory. Is there a bug, or am I missing something? Your assistance will be gratefully appreciated.
RTS does not have sources or targets, it just has folders to watch for changes. If a change occurs in one of the locations, it runs the command at the bottom.
https://freefilesync.org/manual.php?topic=realtimesync
Create a sync config in FFS, save as a batch job (.ffs_batch). Once saved, drag the saved configuration onto the RTS window and it will autofill the locations and command. Choose idle time, save RTS config, put config (or shortcut to it) in your startup folder
