One Source folder to multiple Target folders
dccrens
Hi, Great product!
Is is possible to sync/mittor one source folder (C:\folder1) to multiple target folders like (D:\folder1) and (E:\folder1) at the same time?
Yes you can.
Simply define multiple left-right folder pairs, e.g.
a first pair: C:\folder1 => D:\folder1
and a second pair: C:\folder1 => D:\folder1
You should only do this when using a Mirror or Update sync variant, because these variants do not modify the content of their left-side locations.
And thus, although the two left-side location overlap (here: fully), there is no risk of the sync actions of one pair affecting the other pair. (FFS raises a warning if that could potentially be the case)
You actually want:
C:\folder1 => E:\folder1
The conflict he mentions with two-way syncing is that adding things to "E:\folder1" would sync to "C:\" and then to "D:\" over the next two syncs, and vice versa. If this is what you want to happen, you should make those two pairs two-way syncs and add a third two-way that syncs:
D:\folder1 <=> E:\folder1
so everything syncs in one shot
Sorry, xCSxXenon is right. I made a confusing typo.
My second folder pair should have read:
dccrens
Thanks All! That is what I was looking for!
