[Done] Don't Sync this file if Exceeds a certain size
Stan_Smith
I use FreeFileSync as a contributor and I find this software really exceptional :)
I would like to know if it is possible to synchronize files, in mirror mode, and if it exceeds ~1 GB, not to transfer it to the target folder.
Sincerely
In the Include/Exclude filter (F7), you can also select a minimum and/or maximum size of the files to be included in the sync (top-right).
Stan_Smith
i don't see it, thanks =)
What do you mean "I don't see"? It is pretty clear:
Stan_Smith
FileSizeFilter.png Plerry, 11 Apr 2023, 11:52
I said I hadn't seen it but now it's good, sorry mistranslated.
