Any chance of an iOS version?
Red
I am trying to sync my Minecraft Bedrock saves with the PC version (same save type), and I think the only way to do it correctly would be FFS, I also have a Mac, so either an iOS port would work, or some way to sync it through the Mac to the iPhone. Thanks!
Did you bother visiting the download page ?
Red
Did you bother visiting the download page ? Plerry, 20 Apr 2023, 08:55
I already know that there is a macOS version, but you can’t select a folder on an iPhone, so it wouldn’t work for this.
Obviously, there is no FFS for an iPhone.
You should be able to sync your PC or MAC with your iPhone via USB using FFS,
but you would need to set your iPhone in the USB MTP (Media Transfer Protocol) mode.
Check the Internet on how to do this.
This may vary per iOS version.
As far as I know, iPhone does not expose app data to the computer. Only Android has given that option. You will need to use cloud saving, if it exists, or you won't be able to do what you are looking to do
