Every few seconds, FreeFileSync plays remind.wav. However, there is no dialog box and no sign of what is causing it. I know that it is FreeFileSync playing it from a diagnosis using Procmon. Any suggestions?
Version 12.3 64bit Windows Donation Edition
remind.wav keeps playing
Maybe an earlier instance of FFS hung in memory?
Quit FFS, check Task Manager & see if any "freefilesync" still show up?
Remind.wav says its set for "unattended error".
So also maybe something is noted in your logs?
Ta. I deleted all instances and restarted, but it came back.Maybe an earlier instance of FFS hung in memory?
So also maybe something is noted in your logs? therube, 19 May 2023, 15:11
Nothing noted in the logs
That's the answer. Many thanks. I had tried a search before postiing, but it didn't flag that.
Fixed in the next version: viewtopic.php?t=8535#p39347
