So I have created a task in FreeFileSync, exported it to .ffs_batch file, imported that file to RealTimeSync, executed it by pressing Start - and it works: i.e. my backup folder got updated to the state in which the original is and keeps being updated
But now my question is: how do I start his monitoring and updating process automatically whenever my Windows 10 Enterprise 20H2 starts?
I do want to keep clicking that Start button - all I wanna see is an icon in the Tray notification to know if RealTimeSync is running and have 100% certainty that it is doing what it would be doing if I had opened its window and pressed that button myself
How to avoid having to push the Start button in RealTimeSync?
Save the RTS configuration and put it in your startup folder
%homepath%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
So it is as simple as putting in
C:\Users\YOUR-USER-NAME\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
a shortcut to a BAT file with content of e.g.
while also making sure that this LNK file leading to that batch file has its
Properties > Shortcut > Advanced Run as administrator
turned on to avoid blockades?
start "" "C:\Program Files\FreeFileSync\RealTimeSync.exe" "C:\MY SCRIPTS\FreeFileSync Jobs\test of automation.ffs_batch"
No, you use the .ffs_batch configuration to create a RTS configuration. The RTS configuration will be saved as a .ffs_real file
https://freefilesync.org/manual.php?topic=realtimesync
So I have now
C:\Users\YOUR-USER-NAME\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\test of automation.ffs_real.lnk
and it does start RealTimeSync wit that job of mine. But despite turning on
for it I get the[...]
[...] Synchronizator, 08 Jun 2023, 16:10
blockade infoERROR_ELEVATION_REQUIRED: The requested operation requires elevation. [AdjustTokenPrivileges(SeSecurityPrivilege)]
What has worked for me was going to
and selecting
Properties > Compatibility > Settings > Run this program as an administrator
and then putting in the Start system folder an LNK leading to BAT which runs my FFS_REAL file
Because I can either do the above - or put in Start an LNK leading directly to FFS_REAL file, which does not work [i.e. the pogram does not start automatically after Windows boots up]. The same thing happens [i.e. RealTimeSync does not starts with Windows] if use such Registry hack
which approach when utilized by me for every other program so far has no issue of running affected software through shortcut put in Start folder
So to sum up:
A] The help info at https://freefilesync.org/manual.php?topic=realtimesync should have a small summary at its beginning like:
1] Use FreeFileSync to create FFS_BATCH file with jobs
2] Import it to RealTimeSync
3] Export them to FFS_REAL file
4] Put shortcut to it in the StartUp folder
This way discussions like this one and that one viewtopic.php?t=1124 could be most likely avoided
B] Doing the above point A does not work for me
and selecting
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers]
"C:\\Program Files\\FreeFileSync\\RealTimeSync.exe"="RUNASADMIN"
So to sum up:
Yes. When I deselect
Tools > Options > Copy locked files (requires administrator rights)
Tools > Options > Copy DACL, SACL, Owner, Group (requires administrator rights)
I can then relay on having just
without a BAT intermediary executing it. But then RTS gets blocked when trying to update e.g.
C:\MY PORTABLES\Mp3tag\Mp3tagError.log
and thus after all I do need to use such BAT scripted workaround
So thank you both for you help, as I am now able to operate - but the last issue of this conundrum would be to have an explenation for why
which forces me to use less elegant solution[...]
which approach when utilized by me for every other program so far has no issue of running affected software through shortcut put in Start folderWindows Registry Editor Version 5.00
[...] Synchronizator, 12 Jun 2023, 10:28
going to
and selecting
Long story short:
the optimal way to deal with the whole shebang is to use options
FreeFileSync > Tools > Options > Copy locked files (requires administrator rights)
FreeFileSync > Tools > Options > Copy DACL, SACL, Owner, Group (requires administrator rights)
then implement this REG hack
then finally create an LNK with its Target set to
and in the end put this LNK it in the
system folder - without a need to having selected for it the
Properties > Advanced > Run as administrator
option
This way the elevated synchronization process will not skip up-front potentially multiple items in targeted paths, user does not have to deal with an intermediary launcher script and bypasses the UAC restrictions - which built-in Windows feature is the culprit that prevents anything requiring Administrator rights to be auto-launched directly from the StartUp folder, even if this operating system's security measure will be partially subdued when user selects
Control Panel > All Control Panel Items > User Accounts > Change User Account Control settings > Never notify
option. And so, this deals with the
And at the very end the only thing that still will has to be dealt with are some mandatory Exclusions for Filter in FFS like e.g.
and some individual ones like for example
if user happens to use such programs that use blocked files
But if my above explanation and solutions are wrong in any way - then do please correct me
[HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers]
"C:\\Program Files\\FreeFileSync\\FreeFileSync.exe"="RUNASADMIN"
C:\Windows\System32\cmd.exe /c start "" "C:\Program Files\FreeFileSync\RealTimeSync.exe" "C:\q\FreeFileSync _ RealTimeSync - Jobs\TEST JOB.ffs_real"
option
mystery[...]
AppData\Local\Microsoft\WindowsApps\
AppData\Local\Temp\
AppData\Local\BraveSoftware\Brave-Browser\User Data\Default\Cache\Cache_Data\
AppData\Roaming\ASCOMP Software\BackUp Maker\logs\*.log~
