Hello helllo people. I have the habbit of syncing my folders/files among my internal drives by using their name instead of assigned letter, so far i had no issues but is there anyone who had or maybe the developers have some warning that would be good to know, either while manually sync or realsync?
Cheers and beers.... ( no i drink no beers)! :)
Drive name instead of letter habbit.. any known issue?
I am not sure what you mean by "their name" and how you specify/use those names in FFS.
But this may be helpful:
FFS can also work with unique volume names and/or GUIDs.
Welp, the volume name is the drive name as i wrote it, but no, that article is no answer for my simple question, but i doubt i will ever have any issue unless i change the drive's name or forget to name a new drive.
So, it seems you are using exactly what is described for option 1 in my link above ...
