I have the donation version running under Ubuntu 22.04.
Why can't I see any options to optimise performance? The Comparison Tab in Synchronisation Settings has the Heading "Performance Improvements:", but there are no options to specify Parallel File Operations.
No Performance settings
If you have not yet entered any folder pairs, Parallel will be blank like that.
Enter a folder pair & the options should then turn up.
Irrelevent anyway, it still does one file at a time. Parallel File Operations seems to have to no effect.
It sais "X amount of threads" but is still just transfering 1 file at a time from one location to one location and doesnt move to the next location until that first one is done
Unless im missing something
That's simply not true.Irrelevent anyway, it still does one file at a time. GameOver, 30 Aug 2023, 08:45
Yes. Not all scenarios benefit from multiple threads: https://freefilesync.org/manual.php?topic=performanceUnless im missing something GameOver, 30 Aug 2023, 08:45
For local syncs you may not see a large improvement. Sync'ing over the internet? You *need* multiple threads.
It is not untrue, it only transfers 1 file at a time. and for a local sync there is no improvement, if anything it goes slower.That's simply not true.Irrelevent anyway, it still does one file at a time. GameOver, 30 Aug 2023, 08:45
For local syncs you may not see a large improvement. Sync'ing over the internet? You *need* multiple threads. Zenju, 30 Aug 2023, 09:55
You're talking nonsense. Got any proof?It is not untrue, it only transfers 1 file at a time GameOver, 31 Aug 2023, 05:52
It is expected to be slower for local transfers, there is no artificial limitation on transfer speed when you transfer locally
It's not expected to be slower(*). In worst case, multiple threads will be just as fast as using a single thread.It is expected to be slower for local transfers, there is no artificial limitation on transfer speed when you transfer locally xCSxXenon, 31 Aug 2023, 14:00
*) Unless you're using an ancient spinning disk, in which case multiple threads may introduce additional seek overhead.
Even with SSDs, you still have some overhead for I/O, it just won't be as noticeable or won't be perceivable by a human. Not including the fact that some lower-end CPUs can also have issues with multithread transfers, albeit not super common.
The program only doing 1 file at a time?You're talking nonsense. Got any proof? Zenju, 31 Aug 2023, 07:02It is not untrue, it only transfers 1 file at a time GameOver, 31 Aug 2023, 05:52
Showing syncronizing this file, then this file, then this file. ONE AFTER THE OTHER
Does it says [2 threads] before the path and name of the file it is transferring?
It probably does, or you don't have it set up correctly. FFS will only display a single file's progress at a time even though multiple threads are in progress
Well thats just daft. :) I'll leave it at thatDoes it says [2 threads] before the path and name of the file it is transferring?
It probably does, or you don't have it set up correctly. FFS will only display a single file's progress at a time even though multiple threads are in progress xCSxXenon, 03 Sep 2023, 14:16
Have swapped my backup solution to a drivepool which has created another issue but i do notice using the performance monitor on the Drivepool that it is atleast doing a few files at once if selecting 32threads.
I'll assume it's working then...
It is set up this way because it can't display all current transfers with the limited room. For a few threads, it's fine. But consider five or more threads or, depending on how it is rendered, the different resolutions and pixel densities that are out there
