13.0 Donation Edition can not install in Win 11
Today FreeFileSync show 13.0 are available,but i can not install.It show "installer file has invalid content ...Setup.key" I use win 11.
Downloads from outside of China frequently get corrupted because garbage TCP packages are deliberately inserted by [government agency]. There is nothing FreeFileSync could do about this. Try downloading a few times, until it works.
13.0 portable version work for me,I strongly suspect that there is a problem with the installation package
Same problem, even through proxy server.Downloads from outside of China frequently get corrupted because garbage TCP packages are deliberately inserted by [government agency]. There is nothing FreeFileSync could do about this. Try downloading a few times, until it works. Zenju, 13 Sep 2023, 11:04
aka, Registered.dat, should be identical between any particular version number - regardless of packaging (.exe installer vs Portable)....Setup.key
You might compare the two files & see if in fact they are identical.
(Matter of fact, you could compare all the files. [You'd have to extract them from the _Setup.exe to do that.] And they should all be identical except for [the name] Registered.dat vs ..._Setup.key, & [likely] animal.dat.
[Looks like there was a silent update, so if you compare from a download of 2 days ago vs a download from today & if there are diffs there, just download the installer, again.)
Aside from the .key file, the _Setup.exe itself (on Windows) should (?) hash compare, regardless (?) (& aside from any silent updates) ?
sha1:
sha1:
dbbccffaf9febd99d8ee88882ec3011eafedf194 *FreeFileSync_13.0_[Donation_Edition]_S
etup.exe 09/13/2023 12:17:48 PM
FreeFileSync_13.0_[Donation_Edition]_Setup.exe -> SHA1: DBBCCFFAF9FEBD99D8EE88882EC3011EAFEDF194
The file is the same as the one on your computer. Maybe the problem is caused by Windows system.
System info:
Version Windows 11 Pro for Workstations Insider Preview
Version 23H2
Operating system version 25931.1000
Experience Windows Feature Experience Pack 1000.25931.1000.0
System info:
Version 23H2
I have the same problem in win10 today
C:\Users\Tom>certutil -hashfile C:\Users\Tom\Downloads\FreeFileSync_13.0_[Donation_Edition]_Windows_Setup.key md5
MD5 的 C:\Users\Tom\Downloads\FreeFileSync_13.0_[Donation_Edition]_Windows_Setup.key 哈希:
608d2dcdfe0b5f4741947e9feaa42a6b
CertUtil: -hashfile 命令成功完成。
C:\Users\Tom>certutil -hashfile C:\Users\Tom\Downloads\FreeFileSync_13.0_[Donation_Edition]_Windows_Setup.exe md5
MD5 的 C:\Users\Tom\Downloads\FreeFileSync_13.0_[Donation_Edition]_Windows_Setup.exe 哈希:
b02288ccfb61a738e46b8b27e4628590
C:\Users\Tom>certutil -hashfile C:\Users\Tom\Downloads\FreeFileSync_13.0_[Donation_Edition]_Windows_Setup.exe sha1
SHA1 的 C:\Users\Tom\Downloads\FreeFileSync_13.0_[Donation_Edition]_Windows_Setup.exe 哈希:
C:\Users\Tom>certutil -hashfile C:\Users\Tom\Downloads\FreeFileSync_13.0_[Donation_Edition]_Windows_Setup.key sha1
SHA1 的 C:\Users\Tom\Downloads\FreeFileSync_13.0_[Donation_Edition]_Windows_Setup.key 哈希:
db18c24216fe0fb4e126ee29aac47f35f497a096
system info:
win 10 home 22h2 19045.3448
system info:
Can you write me an email with the address you used for the donation? Then I can check if the md5 of your key is okay.I have the same problem in win10 today
CertUtil: -hashfile 命令成功完成。 ShaoMinghui, 16 Sep 2023, 02:19
Same problem in Win 11, and also the portable one works for me.
If you send me an email I'll reply with a test version that includes some more error details in the error message.Same problem in Win 11, and also the portable one works for me. emile, 16 Sep 2023, 08:20
I have sent you a email, please check.If you send me an email I'll reply with a test version that includes some more error details in the error message. Zenju, 16 Sep 2023, 08:44Same problem in Win 11, and also the portable one works for me. emile, 16 Sep 2023, 08:20
The issue has been fixed! Please download the updated installer from the FreeFileSync homepage.
Turns out there is some weird behavior/bug: When InnoSetup searches for the 0 character via a macro (#0) on a system with Chinese locale, it returns the wrong result. Converting #0 to a Unicode string first, fixes the search. Don't ask me why.
Thanks ,It works~!
I have the same Problem. my FreeFileSync_13.9_[Donation_Edition]_Setup.key is not able to install on Windows 10. What should I do? I want to have a simple solution, because I am not acquainted with PCs because of my high age (75). Thank you
