23:23:33 Ошибка: Невозможно найти следующие папки:
\\192.168.7.5\backup_office\1c_sql_base
\\192.168.7.5\backup_office\Assistant\saunbas
\\192.168.7.5\backup_office\Backup_DC
\\192.168.7.5\backup_office\Exchange
Невозможно соединиться с "\\192.168.7.5\backup_office".
ERROR_ACCESS_DENIED: Отказано в доступе. [WNetAddConnection2]
Hello. I launch FreeFileSync from the windows task manager. I get an error when accessing a network folder. I have full access to the folder.
Free File Sync error ERROR_ACCESS_DENIED
Are "task manager" & "I have" one in the same?I have full access to the folder
As in does task manager & "I" run with different credentials?
If outside of task manager, if "I" (you), who has full access to the folder, "manually" run a sync (so fire up FFS set left side to c:\needs 2 backup\, & right side to \\192.168.7.5\backup_test), does that work as expected?
I ran the task from both my account and the system account.
Everything worked before updating to version 13
That's how I'm configuredIf outside of task manager, if "I" (you), who has full access to the folder, "manually" run a sync (so fire up FFS set left side to c:\needs 2 backup\, & right side to \\192.168.7.5\backup_test), does that work as expected?
I didn't see "error_not_authenticated" specifically, but maybe something in here, WNetAddConnection2?
https://freefilesync.org/archive.php
If you (update to 13.1, or) revert to 12.5, does your sync again work?Everything worked before updating to version 13
I found the problem. I did not run the task with the rights of another user. Thanks everyone for your help
