Renaming folders on backup drive without copy/delete
jackcasey
On my primary drive I have reorganized and renamed many of my folders, but they all still contain the same data and have not changed at all other than their name. Is there a way to sync this on my backup drives without deleting the folders with older names and copying over the new ones since they are essentially the same?
> Is there a way ...
Only the folders involved in your sync were (pre-renaming) previously in sync using FreeFileSync (FFS)
AND you used the FFS database-file (the Detect Moved Files option).
