copy a large folder to multiple smaller locations
I have a large folder and would like to copy/sync the location to multiple smaller destinations, each would contain a portion of the larger folder. Can I use freefilesync to help split this up and decide what files can go on each destination HDD.
If your large folder comprises multiple subfolders, then you can use FFS and define multiple left-right base folder pairs. E.g.
C:\SourceFolder\SubFolder1 => E:\Backup\SubFolder1 and
C:\SourceFolder\SubFolder2 => F:\Backup\SubFolder2
etc.
If your large folder does just comprise many files, then you can use FFS and divide the different file-types over multiple backup locations using multiple left-right base folder pairs and suitable Include and/or Exclude Filter rules. E.g.
C:\SourceFolder => E:\Backup\JPG_files , with a local Include Filer where you replace the default *(=everything) by *.jpg (=all jpg files),
C:\SourceFolder => F:\Backup\PDF_files , with a local Include Filer where you replace the default *(=everything) by *.pdf (=all pdf files), and
C:\SourceFolder => G:\Backup\AllOtherFiles , where you leave the local Include Filter as * (=everything), and add two lines to the local Exclude Filer:
*.pdf
This last pair will then backup everything else (than jpg- and pdf-files) to said G: location.
Note:
For Global Settings you use the icons above the folder pairs, for Local (=folder pair specific) Settings you use the icons in between the left and right location of each pair.
etc.
Note:
