Increase Sync Time
salr39
Hi All,
Wondering if there is a way to increase the sync time on RealTimeSync?
Currently in the test environment, when I modify two files in a row it will sync over, however when I create/modify one file and leave it for 10 minutes it either doesn't sync the file until I have made changes to an additional one or it doesn't sync at all.
Is there a way to adjust this?
Thanks!
The only time in RTS you can adjust is the Idle Time.
See the RTS Manual page.
