Time Span
Hi, I would like to ask Time Span if there is any chance that it can be expressed in hours.
thank you for your reply
What I need is that there will always be only the last x hours in the folder, and other files will be removed. Currently, I use the system schedule to remove the folder.
In FreeFileSync (FFS), files that do not pass the Filter rules are not considered for any sync actions.
So, if you set the Time Span to 1 Day, only files modified in the last day are considered for syncing; any files with an earlier modification date/time will neither be compared, copied, updated nor deleted by FFS.
As you can see, even if it would be made possible to set the Time Span in hours, it is no a solution to your use case.
