There's a new feature in the changelog of FFS 13.4 that I'd like to give my 2 cts about:
"Ignore leading/trailing space when matching file names"
Changes like that may produce confusion down the like. For instance, I have a transparent encrypter that will see any difference in file names as different files and I'd very much prefer FFS to do the same. I always enjoyed FFS for its precision in such things. If it now begins to undermine this principle, its filters will become less and less reliable too.
And once you start in this direction, it may lead to the situation that the file names "one and a quarter pints of beer.txt" and "1.25 pints of beer.txt" will point to the same file since mathematically the names represent the same amount of beer.
Has this been requested by the userbase anyway? And if so, why?
I hope this change will be reverted.
Why ignore leading and trailing spaces?
It's an interesting issue, and I agree that it's not good to ignore differences. I think we need to understand why a file may have leading or trailing spaces. If it could be intentional, yes, I agree that FFS should treat differences as differences.
To better understand this issue:
Which file systems support leading spaces in file names?
Which file systems support trailing spaces in file names?
You're misunderstanding the feature. FreeFileSync still treats these file names as different, but matches them as pairs after comparison.
I'm misunderstanding, missing the distinction. Explain?
1. files with leading spaces, trailing spaces, & both leading & trailing spaces.
- the $ sign is the EOL marker, "showing" that the X-files do indeed have trailing spaces
2. 13.3
3. 13.4
- note that i am also displaying = files, & that there is the 1 file i updated after the initial sync
2. 13.3
3. 13.4
Oh, so you're saying that when (alpha) SORTING the list of names leading/trailing spaces are ignored,
such that all the X-files are grouped together, & all the S-files are grouped together.
Ah, OK.
Ah, OK.
Exactly!Oh, so you're saying that when (alpha) SORTING the list of names leading/trailing spaces are ignored, therube, 05 Mar 2024, 17:10
"file.txt" and " file.txt" will be shown as a renamed file on a single row rather than two rows (1. exists left only, 2. exist right only), in the same way that
"File.txt" and "file.txt" is also matched on one row.
Can I request a feature toggle to allow us to ignore leading and trailing spaces - or multiple spaces either end? The reason being I copied across a large number of files using Windows explorer and it hit them with this great feature: https://answers.microsoft.com/en-us/windows/forum/all/windows-explorer-removes-leading-spaces-from/91126656-1c41-418c-80c1-b38873c3582f#:~:text=When%20copying%20files%20in%20Windows,removed%20during%20the%20copy%20process.
