ERROR_ACCESS_DENIED: Access is denied. [CreateFile]
TonyK1321
Hello - When I run FFS, at the end when it tries to write the log file to:
C:\Program Files\FreeFileSync
I get this message:
I'm running FFS as a user not as an admin. What can I do to allow FFS to write the log file to that location?
Thanks,
Run as admin or change permissions to that location
Log files don't usually write there though, are you sure you want that?
TonyK1321
Thanks. I decided to change the location of the logs to a different sub-dir. It works now.
By default, the FFS save-location for log-files is C:\Users\[UserName]\AppData\Roaming\FreeFileSync\Logs
So, you must have changed that previously.
He probably extracted the "portable" installation into C:\Program Files\FreeFileSync
Pinciano
Problem solved:
I run my FreeFileSync in a Windows 11 machine and I´ve been dealing with this ERROR_ACCESS_DENIED problem bc i changed the letter of the disk where FFS was installed.
Long story short: Don´t open the FreeFileSync.exe file: instead go to the bin directory and execute FreeFileSync_x64.exe.
therube
@P, while that may have worked around your issue, I would think that is not the correct way to go around it.
Also thinking that your issue was not ? dealing with the writing of the .log file?
If it did, that would mean that \Program Files\FreeFileSync\ was a "protected" place, where \Program Files\FreeFileSync\bin\ was not - which wouldn't make sense (IMO).
(There could ? also be other potential gotcha's to running x64.exe directly ?)
So if FFS were installed into C:\Program Files\FreeFileSync, & you thru a new "C:" drive in there, & moved/renamed the old to D: (or whatever), & changed your desktop shortcut to point to D:\Program Files\FreeFileSync... not sure why that should affect things, necessarily? (Anything that dealt with the Windows Registry, sure.)
Pinciano
That was not the issue. If FFS is installed into C:\Program Files\FreeFileSync, and I executed the direct access from the desktop (I suppose it is the 32 version) , ffs can’t create any file in my computer. I checked it and only if I run the 64 version I don’t have any problem.
