Insufficient disk space WEBDAV [RESOLVED]
Adrien66
I tried to transfer my files from my SSD to my webdav server connected to my windows explorer. Unfortunately an error message appears saying that there is not enough space, even though I have 2Tera on the cloud.
Here's the screenshot
It depends on how much data in your cloud-space needs to be updated.
Also read this thread.
Adrien66
Thank you very much for your reply, unfortunately I can't find a solution in the shared thread.
Looks like you need 160 free but only have 17.1 available
Adrien66
Yes, that's what I saw too. However, I do have 2tera storage.
However, I clicked on "ignore the alert and continue" and the download is taking place.
It seems to be a long standing (and still unfixed) WebDav problem, making both Windows and Linux reporting the used and available space of the local disk.
See e.g. in Google or even previously in the FFS forum.
Adrien66
Thank you very much, in fact on the thread with the second link, someone just explained that they had ignored the message in order to continue the transfer in the same way as I had done. So I think the problem has been solved in relation to the thread I created! Thanks to all
