I have just set up a new machine with a fresh install of Ubuntu 22.04 (with xorg) and echo $DISPLAY :0. Previously I had no problems backing up with FFS and naturally I expected no glitch with the new set-up. How foolish. :-)
Line from crontab:
#Accounts to DB
00 13 * * * DISPLAY=:0 /opt/FreeFileSync/FreeFileSync /home/byson/FFS/Accounts.ffs_batch > /home/byson/logs/backup3.log 2>&1
The log gives me:
Authorization required, but no authorization protocol specified
17:00:01: Error: Unable to initialize GTK+, is DISPLAY set properly?
And the log file is, for some reason owned root:root
An clone of that line:
#Tbird
00 15 * * * DISPLAY=:0 /opt/FreeFileSync/FreeFileSync /home/byson/FFS/Tbird.ffs_batch > /home/byson/logs/backup5.log 2>&1
Gives the same error but the log file is owned user:user
These lines BOTH functioned on the old machine (also Ubuntu 22.04.)
Any suggestions as to what I have done wrong ? I am certain this has been answered before ( I may even have answered it myself) but this is new to me...
Strange new behaviour from cron
Depending on the cron implementation in Ubuntu, and where you are storing your cron job, you might need to (get to) specify the user that should run the command.
For example, when I place a cron job in /etc/cron.d/40_myappname_cron I use this format:
But if I were to place a job for this in crontab -e when running as the user, I wouldn't include the intended username because it's already just my cron table.
Also, I cannot seem to recall details if you might need to do something with xauth so your user can use :0, if say, at the time the process is supposed to run, this user is not the one logged in on the graphical terminal session (CTRL+ALT+F7, or is it F1?).
00 13 * * * bgstack15 DISPLAY=:0 /opt/FreeFileSync/FreeFileSync /path/to/file.ffs_batch
00 13 * * * DISPLAY=:0 /opt/FreeFileSync/FreeFileSync /path/to/file.ffs_batch
Thanks for the response.
The jobs were all set up with crontab -e, and I am the sole user. The batch files are all in a FFS directory under home as you can see. As I said, this USED to work fine. :-(
I have downgraded from Donation Edition v 13.5 to version 11.27 and it all works.
What is that all about ??
I have this in my cron and it works correctly with my donation edition.
0 23 * * * DISPLAY=:0 /opt/FreeFileSync/FreeFileSync /home/secret/something.ffs_batch > /dev/null 2>&1
I used crontab -e as well and am only user.
A cron howto has been added to the manual: https://freefilesync.org/manual.php?topic=schedule-batch-jobs#linux
I have been at this for over a month but I cannot get this to work via crontab -e. It works fine from terminal but not from crontab. Running Debian 12 and latest version of donation version.
I've tried with bash scripts I've tried like in the doc above nothing.
40 21 * * * DISPLAY=:0 /opt/FreeFileSync/FreeFileSync /mnt/path/ServerBackup/FreeFileSync/sitebackup.ffs_batch > /dev/null 2>&1
This does not work if I output it to a log I can see the same
I'm losing my mind!
I'm losing my mind!
It's possible that your DISPLAY is a different value. Perhaps when you've logged off, and your computer is just at the login screen, the DISPLAY might be :0.0 or :10. That's not very likely, but possible. If you've left your session logged in, then most likely DISPLAY=:0 would still suffice. Searching how to find the DISPLAY on your "display manager" might help you.
I've tried everything this is crazy. It's really too bad Free File Sync is by far the best sync program I have ever used. I just want it to do nightly sync's on my Linux server from one HDD to another. I legit might install Windows server instead of Linux at this point LOL
This is superfluous, as "DISPLAY=:0" is the default. Settings this environment variable is only useful for values other than ":0".DISPLAY=:0 bgstack15, 22 Feb 2025, 21:21
Have you tried:
DISPLAY=:1
Specifically with cron, there is no default environment variables. Historically, cron has always completely wiped the environment, including PATH. So it's worth setting DISPLAY=:0 in crontab. A user should always set every environment variable that matters.
It's set by FreeFileSync.Specifically with cron, there is no default environment variables. Historically, cron has always completely wiped the environment, including PATH. So it's worth setting DISPLAY=:0 in crontab. A user should always set every environment variable that matters. bgstack15, 27 Feb 2025, 13:32
Today I tried the following in crontab -e
40 21 * * * DISPLAY=:0 /opt/FreeFileSync/FreeFileSync /mnt/hdd/ServerBackup/FreeFileSync/sitebackup.ffs_batch > /mnt/hdd/ServerBackup/FreeFileSync/ffs_script.log 2>&1
40 21 * * * DISPLAY=:1 /opt/FreeFileSync/FreeFileSync /mnt/hdd/ServerBackup/FreeFileSync/sitebackup.ffs_batch > /mnt/hdd/ServerBackup/FreeFileSync/ffs_script.log 2>&1
Those both write to ffs_script.log with the following
20:30:01: Error: Unable to initialize GTK+, is DISPLAY set properly?
I also created a bash script with the same thing and some more logging and it resulted in the same thing.
If I run the bare command from an ssh terminal I get the same error if I run it from a terminal windows when I physically log into it everything works.
I saw someone downgraded that might be my next option. But how do I get an old donation version?
From your personally kept archive of old installers, which likely doesn't exist.But how do I get an old donation version? droidkid, 01 Mar 2025, 01:37
viewtopic.php?p=46112
This was the fix for me - installing Xvfb. I'm on Debian 12 with the latest FreeFileSync, for info. Added it to my own users crontab (not root/sudo) and it now works. Without the info on the other discussion I was getting the same issue.
ffsimon
I followed the method described in the viewtopic.php?p=46112
finally is working again, thanks.
