Sync File Wrong Extra Copy
Hydray
Hi folks, when I use the software to mirror the files, compare screenshot shows like this:
It looks like all files are correct.
Before I click the mirror button, the parent folder of the destination shows like this:
After I click the mirror button, the parent folder of the destination shows like this:
It seems the software copied all files to where they should be, and also acciently copied them to the parent folder of the destination.
Could someone help me to figure this out?
Thank you
Don't double post.
viewtopic.php?t=11324
