Hello. I'm new to the forum. I have a backup situation that I'm trying to see how I can easily accomplish in FreeFileSync. I have a folder with several subfolders. I want to synchronize several of the subfolders but not all of them. From what I understand about the FreeFileSync interface, I would have to select each subfolder individually and synchronize it. The process seems a bit tedious since there could be several of these.
I commonly use WinSCP to perform synchronization with several of my cloud accounts. I can individually select subfolders and tell it to synchronize only those folders. To me, that is the most straightforward interface. Is something like that possible in FreeFileSync? Thank you.
How can this be easily done?
Thank you. That's what I was looking for. It helps alot.
