Is it possible to make FreeFileSync create duplicate files?
Miss_M
Hi :-)
I wonder if it is possible to make FreeFileSync create duplicates?
I just got a photo ruin by bit rot and FreeFileSync copied over the good photo on my backup drive with the bad file.
So i wonder if it is possible to set FreeFileSync to create a duplicate if the files has different sizes and dates?
In windows it create a filename(1).end and in linux its stop copying and asks for what to do. Sadly linucx can not do as windows and just do same action on all files and create a duplicate.. But that is another topic for another forum.
But my question is if it is possible to change something in FreeFileSync so it always create a copy/duplicate if the source file has different size or date?
You want versioning
https://freefilesync.org/manual.php?topic=versioning
You should also consider implementing a proper backup solution. 3-2-1 strategy isn't perfect if we nitpick, but it is incredibly better than the average person has or needs.
Miss_M
You want versioning
You should also consider implementing a proper backup solution. 3-2-1 strategy isn't perfect if we nitpick, but it is incredibly better than the average person has or needs. xCSxXenon, 02 Jun 2024, 15:04
Thanks for the link, i will look in to it and do a lab test to only modify size but not timestamp on the file to see the versioning works. :-)
I have a three step backup... first to my server from my computers, then i backup the server to external disks and those also get backed up offsite.
I did fortunately saw it after the first backup, so i could get the picture back from server backup disks.
But if i hadn't seen it, it had become a domino effect where all disks had been effected.
So from now i will not use FreeFileSync from the server to the external disks until i can see FreeFileSync can create duplicates if the file size has changed but not time.. as bit rot often changes the filesize even the date are unchanged.
therube
Not that I know, particularly, but I'd think that, odd.
Miss_M
Not that I know, particularly, but I'd think that, odd. therube, 03 Jun 2024, 16:22
I will look in to it when i get a bit more time. :-)
