Italian translation update
Report translation and localization issues
Antonio.A
italian.lng
Hi all!
I attached the file italian.lng with some modification (e.g. "cartella" instead of "directory") and missing terms.
Hope this helps.
Best greetings.
Antonio.A
Hi all!
The attached file italian.lng has been updated and completed, and replaces my previous version.
italian.lng
Antonio.A
Yes, "cartella" is the exact translation for "folder" and for "directory" (in information technology context).
Maybe Microsoft does not translate into "cartella" but IBM does and, anyway, there is no reason to avoid translation when an exact translated term exists in our language.
I also attached a new version of italian.lng, with many other terms translated.
"directory" and "folder" are not the same thing.
A directory is a folder, but a folder is not necessarily a directory. E.g. a "virtual folder" is a folder, but not a directory: https://devblogs.microsoft.com/oldnewthing/20110216-00/?p=11473
bovirus
@Zenju
For me "virtual fodler" = "virtual directory" then in Italian is "cartella virtuale"
