folder pairs on hold
manolaia
Hi. Is there any way I can put one of the many 'folder-pairs' I have in FFS, on hold? Meaning, I do not wish to have one of the folder-pair to sync for this instance but will require it to be synced at another time.
Thank you!
Click the minus to remove it and don't save it, as that would overwrite the original configuration. To restore, just click a different sync config from the list and go back to the one you want, restoring the pair you just removed. Restarting FFS should have the same effect.
manolaia
Thank you for the speedy reply.
