ISSUE: Doesn't really know what to do with undated files
ira
I have noticed that if a file is undated, FreeFileSync isn't entirely sure what to do with it. In the case of a mirror, which is what I use, it will just declare it new each time and mirror it.
This isn't necessarily a problem, but it isn't acting true to purpose by copying over identical files.
Thanks!
What is the modification time of the source file as shown in FreeFileSync GUI?
Yeah, I don't think an 'undated' file is possible, but it may be a file that has a timestamp outside of a file system's supported range.
ira
I had repaired the files (redated them) to stop the forever-sync issue, so I no longer have them to test. I was not aware that the undated nature would come under fire. The date column was blank in both FreeFileSync and Windows. In my experience, that also translates to a default date back in 1969.
Should I come across undated files again, I will reopen the issue.
If it helps, 7zip shows the date of those files as 2038-01-18
therube
On my end (Win7), FFS does see the "correct date" [of the file, "D"] (it is dated 12/31/1969), but Windows Explorer shows it as "blank".
(Looks like 2038 is OK ;-).)
ira
Thank you ... hopefully that is enough information to figure out the issue.
By the way ... I can report that the same exact behavior occurs when a file is hidden and starts with a "." (which is what happens when a Mac works on a file). Every file I had which was hidden and started with a "." (e.g., "._Freefilesync bug report.pdf") suffered the same fate ... perpetually showing as needing to synchronize.
