ISSUE: Error Triangle Doesn't Clear
ira
I synchronized a number of folders at the same time, but had forgotten to change to "PERMANENT" instead of RECYCLE, which generated errors.
I tried to clear the error triangle by re-sync'ing, but it remained.
I figured out that the error triangle will not remove itself until there is at least one file to re-sync, even if you have run a brand new compare.
What this means is that it looks like the compare generated an error, which it didn't. It's just the old triangle which persists.
Thanks!
