Cache
jmc33
Hello
I just buy the application and I stop it during transfer
I lost space on my pc disk, can you help me to recover my space free please?
Where the cache is located, I want to delete it
Thank you
JM
There is no cache. The data that was already transferred before stopping will have to be deleted manually
jmc33
ah ok
Its strange because I lost space on my pc
I made a copy from an external disl d: to a drive P in the cloud.
And I really lost 53 Go on my pc...
I dont know why
You could check your temp directory I suppose. Open File Explorer and go to "%TEMP%"
You should be able to delete everything in there safely. There may be some errors, skip any conflicts.
If that fails, I recommend SpaceSniffer to check disk usage. There is a faster alternative, WinDirStat, but I think the interface of SpaceSniffer is friendlier, and it's pretty fast anyway
jmc33
Thank you very much
If that fails, I recommend SpaceSniffer to check disk usage. There is a faster alternative, WinDirStat, but I think the interface of SpaceSniffer is friendlier, and it's pretty fast anyway xCSxXenon, 08 Sep 2024, 19:46
Or just use FreeFileSync's tree view on lower left. That already covers the good parts of all these space sniffer tools, except for the block view, which is less powerful than the tree view IMHO.
Or just use FreeFileSync's tree view on lower left. That already covers the good parts of all these space sniffer tools, except for the block view, which is less powerful than the tree view IMHO. Zenju, 09 Sep 2024, 06:56
I agree with this if you are a semi-advanced user. Using the tree view in FFS requires correctly selecting filters to show the appropriate data and can sometimes lead to the unintended deletion of data if you aren't careful.
Regardless, the OP is trying to discover data usage in a location that wasn't directly involved in the FFS synchronization in the first place.
Regardless, the OP is trying to discover data usage in a location that wasn't directly involved in the FFS synchronization in the first place. xCSxXenon, 09 Sep 2024, 14:59
Yes, this is one of the few non-sync scenarios that FreeFileSync supports: Just select the whole drive on only one side and press "compare". No need to fiddle with filters or something else. Easy peasy.
Yes, this is one of the few non-sync scenarios that FreeFileSync supports: Just select the whole drive on only one side and press "compare". No need to fiddle with filters or something else. Easy peasy. Zenju, 10 Sep 2024, 07:15
Ah yes! That is an option. I will have to test this as I am curious how the speed compares to other alternatives. I do still prefer an overall "geographical" display though, sine SpaceSniffer shows folders numbers of layers down
