Sync order ?
Does the order in which they sync go from top of list to bottom, or does it do it in any order ?
Deletions before updates/creations
Files before folders
A to Z (Alphabetical)
Thanks.
Not quite true, let me clarify:Deletions before updates/creations
A to Z (Alphabetical) xCSxXenon, 15 Sep 2024, 19:39
"Everything that reduces disk space" before "everything that increases disk space". I.e. deletions, and "overwrites of a big file by a smaller one" happen before creations and "overwrites of a small file by a bigger one".Deletions before updates/creations xCSxXenon, 15 Sep 2024, 19:39
The folders containing files obviously need to be created first. If both files and folders need to be created inside an existing folder, then there is no precedence.Files before folders xCSxXenon, 15 Sep 2024, 19:39
No, only the display list is shown alphabetically, but this has nothing to do with sync sequence.A to Z (Alphabetical) xCSxXenon, 15 Sep 2024, 19:39
My analysis was purely based on what my logs showed, and they were consistent across all of them. Nice to know that any operation that reduces space-used is run first. I say "files before folders" because my logs all show subfolders being created only after the creation of the files in the same location. Of course, the same reasoning goes for why I say it goes A to Z, every log I have does this. Must just be a coincidence lolNot quite true, let me clarify:Deletions before updates/creations
No, only the display list is shown alphabetically, but this has nothing to do with sync sequence. Zenju, 16 Sep 2024, 09:01A to Z (Alphabetical) xCSxXenon, 15 Sep 2024, 19:39
So updates/creations are 'completely' random?
