New to FFS with a simple (for you) question.
RealTimeSync (13.7)
For testing, learning, I created a file called "free file" on each (2) drive. Two way sync worked great.
Now I am trying the RTS. I selected each file (word document) but it did not install the command line code?
Thank you in advance for you "hand holding".
New to FFS. Donated member.
https://freefilesync.org/manual.php?topic=realtimesync
You first need to save the FFS settings as a .ffs_batch configuration, and then you drop that into RTS
Thank you xCSxXenon.
Confusing my old brain but I was successful! Practice, patience and a little help.
