display what multiple threads are doing?
hspindel
I just activated the donation edition, enabling me to specify additional threads.
In the Synchronizing window, it only shows me what one of the threads is doing. I can tell that sometimes non-visible threads are doing things in the background.
Any way to see what the non-visible threads are doing? Maybe add a couple additional status lines to the display below the one current status line?
therube
(A "dirty" way, on Windows, you can check something like, Handles, where I'd expect you'd find the file names being processed at a particular time?
System Informer, double-click on the FreeFileSync_x64.exe process. That brings up a dialog box. Select the Handles tab, & within (you can Filter, say c:\) & (I'd suspect) ought to be able to see file names coming & going.)
hspindel
Thanks, I'll give it a try.
