Help with revisions
fjelsten1
Hello
I have tried setting up FFS with daily revisions:
I would like for all revisions within a day to overwrite the files and for the next day revisions to stay within that day's folder.
And this is the important point that I cannot get to work: I only want to keep 7 days of revisions.
It's not really working - if I enable the Days checkbox I get subfolders with timestamps witin each day. What am I doing wrong?
By choosing the "Time stamp [Folder] naming convention, your previous versions get stored in a folder which name is the timestamp. Probably you want to use the "Time stamp [File]" naming convention.
All previous versions of a given file then get stored in one and the same folder, and have a time-stamp added to the file-name.
Then simply select the "Last x days" and enter 7 days.
fjelsten1
Thank you for your reply.
I do not want to rename my files since this makes restoring more cumbersome.
I used to use allwayssync and here it is possible to have all files keep their orginal name, be placed in a revisions folder mirroring the original location but keeping all files updated per day in the same revision day but not at least also to specify keeping only revisions for x days - if that makes any sense.
This is not possible in FFS?
Not as you describe
Setting "Last x days" to 7 is going to keep at least 7 days of file versions in the folder you specify. Obviously, this isn't going to work because a new folder is created every day since you used %date%. Leave it as "Time stamp [Folder]" and remove the '%date%' at the end, leaving "...\Revisions"
This should create the subfolders whose names are the dates and contain the files versioned on said date.
fjelsten1
Thank you.
Yes, but then I get folders like:
Date1 Time1
Date1 Time2
Date1 Time3
Date2 Time1
Folders. I cannot set a time for the backup to run so it's running when the PC is not used.
Switch to "Replace" for the naming convention
https://freefilesync.org/manual.php?topic=versioning
fjelsten1
This seems to work!
Thank you for all your replies.
