I've got a problem excluding word files starting with a ' ~ ' when comparing directories before the update. Tried \~* , ~* and similar entries , but nothing seems to remove this type of file from the search result.
Where do I go wrong?
Many thanks in advance for any assistance.
Problem filtering files..
https://freefilesync.org/manual.php?topic=exclude-files
To get started:
To get started:
Instead of typing the filter phrase manually, go the the FreeFileSync main window, right-click one or more files from the list, and exclude via the context menu.
Thanks, the hint following 'To get started:' did the trick!
cheers.. ; )
cheers.. ; )
