You will need to configure an RTS setup that runs on the computer. It monitors for a location, the name of the external drive for you, and when it is inserted it will run the command you configure.
https://freefilesync.org/manual.php?topic=realtimesync
Automatic synchronization after inserting a USB flash drive
