How to temporarily change sync direction for some files?
dirki-boy
How can I temporarily change the sync direction (not doing it in "Synchronizations settings") , so e.g. when there are displayed none equal files and I want to overwrite (may be 3 of 10, not all) the existing ones on the right, how can I change "Do nothing" to "overwrite"?
wpwoodjr
Right-click on the files and there will be options for that.
dirk-o
Thank you, WPWoodJr.
Yes, I had tried before, strange, on my system there aren't.
