Never overwrite & delete files as default setting?
dirki-boy
Can I make FFS always only to copy the existing files (sync mode e.g. "Update") on the left side to the right side? Without ever overwriting, deleting, changing files on the right side (e.g. none equal files by content or name, date etc.)?
Sorry, of course you can (but it doesn't seem to be, what I want, I will check after the actual sync):
I have set in "Sync settings" "Custom": "Action" "Copy new item to right" the next 2 one below "Do nothing" and the fourth "Leave as unsolved conflict".
So, that should make, what I want, shouldn't it?
So, syncing like you see on the screen shot, will only copy all existing files from the left to the right side, nothing else, is it right? There will nothing be overwritten, modified, just copy the files existing only on the left side will be copied to the right one.
[404, Invalid URL: http://www.fotos-hochladen.net/uploads/dirks2013022qspin5zdc.jpg]
Sorry for asking again, is there any way to get an e-mail notification on new posts? I couldn't find a way, yet.
