error in Linux
gord0
I am running FreeFileSync 14 on MX Linux 23.5 KDE 64bit. I just upgraded from 13.9.
After starting a file comparison the program crashed and the following error was displayed.
"Error starting "/opt/FreeFileSync/Bin/FreeFileSync_x86_64".
Killed by signal 11"
Any help appreciated.
Gord
mmolthagen
same problem here (Kubuntu 24.10 with Wayland) after update to version 14.0. "Killed by signal 11" after starting file comparison.
Greetings
Michaela
gord0
I uninstalled FreeFileSync 14 then reinstalled version 13.9 which always worked in the past. I now get the same error with version 13.9.
Perhaps a problem was introduced with a linux update. Both Ubuntu and MX Linux are based on Debian so it could have originated with Debian. That is just a guess on my part. I will wait and see if someone with more technical ability than me can figure out the problem.
Cheers,
Gord
mmolthagen
On my Notebook (HP Pavilion x360 Convertible 14-dh0xxx with 4 × Intel® Pentium® CPU 5405U @ 2.30GHz, 8 GB RAM, Mesa Intel® UHD Graphics 610) several programs have exactly this problem (FileZilla, Gajim...). All those programs didn't crash months ago, it seems to be new (I connected it to a monitor and a Bluetooth keyboard/mouse combo, maybe I should try without).
My desktop PC (also with Kubuntu 24.10, but completely different hardware) has no problems.
So it might be a problem with Debian updates on some hardware.
Greetings,
Michaela
gord0
I discovered that the problem seems to be with a Mime Type incompatibility. It was causing the Dolphin file manager to freeze whenever I attempted to open a folder with a json file inside. I believe that this was also causing the crash with FreeFileSync. Once I resolved that FreeFileSync ran normally again.
Gord
therube
Care to expand on just what you did to fix your end?
Did you have to create/update something like, $HOME/.local/share/mime ?
gord0
I read a number of forum posts about the file manager, Dolphin, freezing which led me to this one, https://www.mail-archive.com/kde-bugs-dist@kde.org/msg863568.html. It advised deleting the ~/.local/share/mime/ folder. Instead of deleting it I moved it and renamed it. I realize that this is not a proper fix but it is working for now. Here is the first discussion where I read about the problem, https://forum.mxlinux.org/viewtopic.php?t=79890.
I use MX Linux 23,5 KDE.
