I need to sync a folder that's also being synced using Dropbox.
Dropbox have its selective-sync enabled, meaning I can see all the files and their file sizes in explorer/finder but the size of the actual file on disk is 0kb.
If I try to sync the folder with FFS with a size filter of 100kb I'm currently getting all the selective-sync files that isn't synced as FFS checks their file size instead of their size on disk.
Is there a way to check the size on disk instead of the reporting file size to solve this problem?
Filter with size on disk instead of file size
I don't know anything of Dropbox, but does the section on Symbolic Link Handling apply?
