Donating and how does it work
If Freefilesync works for me the way I hope should, and it looks like it will, I will certainly make a donation. My question is since I intend to use it on at least two PC, and maybe a third, would I have to make a donation on all of them or when I make a donation on one will the advanced features also be usable on my other PCs?
From the FAQ on the donation edition:
But I believe there is a built-in check on (excessive) distribution.
So, it is OK to have it installed on more than one computer.The FreeFileSync Donation Edition is expected to be used by you and your friends. ...
