Feature Request for Large Backups
mgilbert
After changing files in, or adding files to a large mirror type backup, performing a "file content" comparison of the entire backup isn't practical, as that can take hours. I'd like the option to do a "file content" comparison of only any files changed in, or added to a backup. Having that as an setting where it occurs automatically after running a backup would be really great.
You want to compare content for just the changes, which requires a full content comparison to know what changed, which means this isn't possible.
That is exactly what FFS already can do.
Simply set the VerifyCopiedFiles flag to True.
mgilbert
Thank you, Plerry. I didn't know about that GlobalSettings file.
That setting changes it for FFS globally though, so every sync will be affected, just be aware
mgilbert
I understand. Under the circumstances, that's exactly what I want. It would be nice, though, if that was one of the options when setting up a backup, so it could be set up individually, per backup.
