Images are attached of the linux v14.2 Donation Edition.
Having issues with the syncing, as i cannot resize the dialog window to press buttons.
luckily the options window and other windows can be dragged down, but there is no scroll on the side of these dialogs, so will be an issue for small screen, or oversized environments.
my screen is a 1080p, so heaps of pixels to go around.
Hopefully a config file can be edited or a hotfix can be pushed to help.
Have not tested on Windows/iOS
Attempts:
1. Reinstall.
2. Reset Layout.
3. resize display.
4. resize other dialogs then sync attempt.
v14.2 DE - Window frame on dialogs is too small
- All dialogs are slim
- FFS window error 2025-03-17 options.png (38.66 KiB) Viewed 2970 times
- Warnings are hidden
- FFS window error 2025-03-17 Warning.png (30.4 KiB) Viewed 2970 times
- Sync buttons hidden
- FFS window error 2025-03-17 sync.png (25.94 KiB) Viewed 2970 times
Which Linux distribution and desktop environment is this?
Mint 22.1 CinnamonWhich Linux distribution and desktop environment is this? Zenju, 17 Mar 2025, 08:42
version 6.4.8
Kernal 6.8.0-55
Intel i7 CPU
X11 Desktop
Hi Zenju
Thank you for the update with dialog height adjustments on some dialogs
I am still having issues with the "Start Synchronisation now?" window. And after the update noticed the About window also same size.
Just wondering if the dialog sets it's height based on screen size? As maybe its taking my 2-3 screens total width and 1 screens height as the size? Is there a minimum width x height set?
Let me know how it works and shall try some ideas?
Is this fixed with the new GTK3 build?
viewtopic.php?t=12713#p49387
Amazing - Shows everything, and went through to test as many windows as i could access and all are showing as right size, and resize function is great for a long directory name.
Sync worked well and no issues noticed.
[14.6-beta x86_64]
