Doesn't start on Arch Linux, removed gtk2 support
obi-juan
Recently arch linux removed gtk2 support which is needed for FFS to start, is it possible to use gtk3 instead?
Isn't is possible to install GTK2 manually via apt-get?
obi-juan
Sadly no, apt-get only works for debian based distributions. Arch removed gtk2 from the official repos recently and more distributions will surely follow, since it reached end of life 5 years ago. There's a way to install gtk2 using AUR but it is not recommended. Is there a way to use FreeFileSync using gtk3 instead?
You're right, but the following should work, no?
sudo pacman -S gtk2
obi-juan
No, gtk2 was removed from the repos, it no longer exists. Only gtk3 and gtk4 now.
DragonFox
Rebuild from source/regular aur, not the "bin" aur
Then it seems to work.
The freefilesync-bin aur package does not resolve gtk2 to https://archlinux.org/packages/extra/any/gtk2-compat/
Here's a build based on GTK3. Any issues with it? Perhaps it's time to give GTK3 another chance. I can't reproduce the issues from last time (viewtopic.php?t=10103). Perhaps wxWidgets has implemented fixes since then:
https://www.mediafire.com/file/ka95dx682a8cs6v/FreeFileSync_14.6_beta_Linux_x86_64.tar.gz
obi-juan
Yes, it works perfectly for me. Will report back if i find any issues with it.
