timestamps
wht
For the filtering criteria in terms of file timestamps, we hope to provide options similar to Robocopy in Windows, such as the following conditions for selection: 1. Files created before a certain date. 2. Create files with a date later than a certain day. 3. Modify files with a date earlier than a certain day. 4. Modify files with a date later than a certain day.
What is available in FFS is https://freefilesync.org/manual.php?topic=tips-and-tricks#select-time-span.
By proper choice of the From and/or To date, you can achieve all of the above.
