RealTimeSinc Autorun
Dellmarr
Greetings! I would like to know if it is possible to make RealTimeSync run automatically after restarting the PC and logging in?
It is very inconvenient to run this program manually all the time.
John1234
Have you tried using Windows task Scheduler? That should do the job.
Dellmarr
Have you tried using Windows task Scheduler? That should do the job. John1234, 19 Mar 2025, 15:01
There is no problem with starting the program itself, but you need to press the Start button in it. How would this happen automatically too?
Dellmarr
There is no problem with starting the program itself, but you need to press the Start button in it. How would this happen automatically too? Dellmarr, 19 Mar 2025, 16:22
I found a solution to my problem on YouTube: https://www.youtube.com/watch?v=TThGBG_Z4N0
John1234
I tried looking at that video but it's not in English.
Don't put the main program in the task scheduler you need to use the real-time sync program followed by the name of the file that you saved to create the real-time sync task.
C:\Program Files\FreeFileSync\RealTimeSync.exe
In the **Add arguments** field, enter the path to your `.ffs_real` file in quotes (e.g., `"C:\Path\To\MySync.ffs_real"`).
Or simply RT(F)M:
official manual or tutorial.
