Hello. Instead of selecting folders to copy (on the left) would it be possible to use a list of files to copy? (a text file containing on each line the path of a file to be copied?)
thank you
You could use the Include Filter to create/provide such list of files to be considered for syncing.
You can manually edit the Include Filter, or run a Compare, select a file, and via a right-mouse click (context menu) add that item to the Include Filter list.
Hello. I have 2000 files to sync using a file list and… it work using filters.
Nice
Nice
