Can I sync an entire (like my drive D:\ in Windows) from PC1 to PC2?
SetSee
Newbie question:
My files on my Windows PC are stored on their own drive (D:\) for simplicity and so that I can have very short pathnames, like D:\$$$\AmEx for a credit card folder. I’ve looked for 15 minutes at the FFS FAQ & Manual, and they seem to imply this can be done, but I did not find any more details about doing it, and searching this Forum’s posts did not yield the answer.
Can I use FreeFileSync to sync the folder (drive) D:\ on my PC-1 to folder (drive) A:\ on my PC-2? Is there a setup step that initially sets FFS up to that FFS on PC-1 is talking to FFS on PC-2?
If you can point to existing documentation or help files that answer this, that would be fine. But I haven't found anything yet about these issues.
This will require setting up a network share on one computer that is able to be accessed by the other. This is something you do prior to FFS being involved at all
John1234
Or, you can like I do use the Microsoft Windows open SSH services that come with Windows as an optional add-on.
This way you can use SFTP.
https://learn.microsoft.com/en-us/windows-server/administration/openssh/openssh_install_firstuse?tabs=gui&pivots=windows-server-2025
These are better.
https://winscp.net/eng/docs/guide_windows_openssh_server
