FFS wants to re-copy files from SD card in phone after daylight savings time starts
I have a bunch of image files on my phone's SD card that I synced before the US switch to daylight savings time. Now when I do a "compare" FFS wants to re-copy these files. Wasn't the whole point of the weird creation dates that FFS puts on FAT files to prevent this issue?
It turned out, even the herculean stunts that FFS pulls are not enough, due to another FAT "feature" called file-system tunneling:
http://blogs.msdn.com/b/oldnewthing/archive/2005/07/15/439261.aspx
In essence, after synchronization, you need to compare at least once more, to freeze file times of last modified files.
Does FFS do this now? Or do I need to do this manually?
Also, I see that there are two options in FFS to skip syncing a file - "space" prevents the file from being synced "temporarily" by "unchecking" it, while "alt-down arrow" is similar but doesn't "uncheck" the file. It would make sense to me, if "alt-down arrow" told FFS not to take action on the file until one or both files changed on a subsequent compare, while "space" was temporary. That would allow me to skip re-copying all my images from the phone. Does that make sense?
