Deleting files after sync
ranso73
I'm sure there will be people who disagree with this and don't see the logic but ...
I would like to use FFS to move files, it has a really nice interface and is a pleasure to use thus far. I have a need to move many files but then delete them after the move. I have directed the sync to run a batch command after the sync but the batch file won't delete from the left and I have no idea what the config should be.
I appreciate that the point of the app is to SYNC, therefore a file on the left should be on the right also at the end of the run, but please help me out.
Many thanks.
