Hello Guys,
i just wonna move files from one site to othersite.. move like move it and delete it after.
Haru
Only move files
Do you need FFS to do this?? I guess you can. You could run a post-sync command to wipe the source, or just do it manually. Is this a one-time effort or something that will be repeated? Did you even attempt a search??
viewtopic.php?t=7770
viewtopic.php?t=7059
viewtopic.php?t=6512
viewtopic.php?t=8401
thank you!Do you need FFS to do this?? I guess you can. You could run a post-sync command to wipe the source, or just do it manually. Is this a one-time effort or something that will be repeated? Did you even attempt a search??
viewtopic.php?t=8401 xCSxXenon, 22 Sep 2021, 14:15
