Are there limits as to the size of directories copied?
tjbourne
I have some design and photo directories that are between 350 GB & 650 GB. When trying to sync them to a directory in a 15 TB flash drive it goes through all the motions but when I go to look at the flash drive there are only folders there, no files.
Are there limits to how large an individual sync can be? What can I do to fix it?
Thanks in advance for any help you can give.
15TB flash drives don't exist, so you probably have a fake one. These are known to delete any data aside from what fits on the real size of the NAND
tjbourne
Thanks for your reply, it was most illuminating. Before this latest failure, I erased and re-partioned the drive, first with Win disk management and then with Easeus Partition Master. Both gave me very similar volume/partition sizes. Since your reply, I have tried h2testw which I was told would see through the fake info and tell me what the true size is. Well, that didn't work either. Do you know of any software that is able to see the real size of the USB drive?
