What happens If fail-save copy fails?
meATffsForum
Is further sync processing stopped?
Or retry?
Or going one, but leaving tmp-files?
Etc.
meATffsForum
I think my description (and header) needs clearification?
As far as I understand "Fail-save copy" helps for special (hopefully rare) situations
when something terrible happens and the copy of a file could not carried out.
My question is:
If FFS is still alive, what does it do then?
- Is further processing stopped?
- Retried?
- Going on with next file, leaving tmp-files and reporting the incident?
I haven't found anything about that.
therube
Fail-safe file copy & VerifyCopiedFiles mentioned:
viewtopic.php?t=10375
(Former default, latter not. Wouldn't expect an issue there, but...)
in conclusion: Some files will be more than 5 times slower when using FFS synchronization across disks.
viewtopic.php?t=10221
(Didn't mention what "some files" might have been. Maybe they were multiple thousands of thumbnail's of his .mp4 files ;-).)
meATffsForum
Shall your post have anything to do with my question?
Depends on what causes the failure
meATffsForum
You're making it exciting... :)
What behaviour of FFS is caused by what situation then?
therube
Shall your post have anything to do with my question? meATffsForum, 02 Jul 2025, 16:02
Actually, no.
(Sorry about that, posted to wrong topic.)
